Previous in Forum: Coal   Next in Forum: how to calculate the empty weight of the vessel shell, bottom and top
11 comments
Engineering Fields - Mechanical Engineering - I am here to help!!
Metal Deposition
04/19/2011 6:49 AM
I am attaching two images. It seems to be a sandwich of soft and hard metal. The soft part is similar to mild steel and I am still working on the hard part.
Can anybody tell me what metal deposition process this could be?
The hard portion is difficult to cut as well as melt.
Good Answers: 88
Re: metal deposition
04/19/2011 8:17 AM
Could be Hard chrome, or some propriatery coating like NICASIL. Also could just be surface hardening. Color difference can be misleading. What kind of equipment was it on?
04/19/2011 9:14 AM
Not much to go on.
It might have been joined by:
Explosive Welding - Explosive Bonded Metals - Explosive Metal Welding
04/19/2011 9:36 AM
Agreed, not much to go on. Scale? Is the piece shown 3/8" thick or 1-1/2"?
Sizes of samples? What comes to my mind is hardfacing, but that is just a shot in the dark. Agree as well, explosive welding or friction welding are also possibilities.
[edit] Looking at the pix again, I doubt that hardfacing would be that thick. The irregular surface would support that technique, but that is a lot of spray deposition.
04/19/2011 11:16 PM
its a half inch thick piece.
I did some googling and quite sure that it is a metal deposition using laser. Still want to confirm it. I was wondering what kind of metal is deposited which is so hard and even difficult to cut with torch.
It is a barrier of safe. Our marketing person gave it to us to study.
04/19/2011 11:34 PM
Good bye.
"marketing person" or people don't have a heart, or a conscience.
04/20/2011 10:00 AM
It is probably from a class TRTL-30 or -60 safe.
Construction of such equipment is, by their very nature, sort of a secret.
What are you studying it for? Are you trying to RE a competitor?
04/20/2011 11:51 PM
Yep. Its a sort of benchmarking. Trying to know what the competitor has done and do something better than them.
I dont think its TRTL 30 or 60. A 1/2" thick plate cannot give so much resistance.
04/19/2011 1:28 PM
Where's Milo when you need him?
J B
Re: Metal Deposition
04/20/2011 4:34 AM
it could be metal cladding with weld overlay, but I'm not sure.
http://en.wikipedia.org/wiki/Cladding_%28metalworking%29
Good Answers: 58
04/20/2011 8:06 AM
If it's part of a commercial product, it's likely a lower cost process. I would guess plasma spray. I would have a chemical analysis performed of the substrate and the cladding. Knowing the chemical composition of the two will aid in figuring out the deposition method. I'm guessing that the cladding is a high cobalt material.
Good Answers: 94
04/21/2011 5:25 AM
Agree with that, possibly flame spray stellite or similar.
Register to Reply 11 comments
Doorman (2); ikhwan (1); JBTardis (1); lyn (2); Nigh (1); pc (2); SimpleMind (1); welderman (1)
