Previous in Forum: smd identification   Next in Forum: Westinghouse DC Generator
8 comments
Unstable Polarity on an Electric Motor
04/19/2011 4:32 PM
I own an old AMF Radial arm saw. The polarity on the motor has become unstable, and tends to start in the reverse position. Can I repair this motor? and how?
Pathfinder Tags: electric motor polarity
Good Answers: 114
Re: Unstable Polarity on an Electric Motor
04/20/2011 12:05 AM
we're gonna need more info if you expect any sort of answer
04/20/2011 9:43 AM
I have basic knowledge of elecrtic motors, and have done things such as replace brushes. I was simply starting a discussion based on my knowledge of the situation. Your sarcasm was uncalled for, tho I hope it made you happy.
Good Answers: 114
04/20/2011 12:34 PM
Welcome to the forum
no sarcasm intended, just a statement of local operational fact
If you tell us things like:
model#
make, size & model# of the motor
date of manufacture
You will be much more likely to get the proper solution
otherwise you see what happens
a bunch of wild guesses
04/20/2011 12:08 AM
Yes, send this to a motor shop. If you want to keep this great piece of equipment running. And I sure hope you do! There are not too many of them around that I am aware of. Since you are only talking about the motor, I am assuming that the ways are still accurate and cut perfectly.
"Real Bass Players" do not use picks
Good Answers: 18
04/20/2011 2:24 AM
Hi Mike,
Although you have not given much information regarding this motor, if the motor is capacitor start then your problem would indicate that the capacitor is faulty.
Replace the capacitor with exactly the same rating and voltage and your problem should be cleared.
On a single phase motor the capacitor will offset the phase angle of the starting winding and thus determines the direction of operation.
Hope this helps.
A little knowledge that acts is worth infinitely more than much knowledge which is idle! Khalil Gibran
Good Answers: 130
04/20/2011 2:40 AM
GA - 99% the case, but it might be dirty switch contacts messing the capacitor up.
04/20/2011 5:51 AM
GA
I would just change the advice from "exactly the same rating and voltage" to the same capacitance and at least the same voltage and temperature rating.
Good Answers: 804
04/20/2011 1:58 PM
AMF (who later became DeWalt) used cap start single phase motors for the most part, so yes, most likely your cap is failing; they don't last forever and if it sat around un-powered for years, the cap could be toast.
Register to Reply 8 comments
34point5 (1); Garthh (2); Jimh77 (1); JRaef (1); Keith Grewar (1); Mike Patek (1); Randall (1)
