Previous in Forum: Motor IP Protection   Next in Forum: Power Factor
India - Member - New Member
Grid Rotor Resistance Vs Liquid Rotor Resistance.
04/21/2011 8:24 AM
dear All,
What is the advantage of GRR over LRS. advise me
Knowledge Sharing
Good Answers: 804
Re: Grid Rotor Resistance Vs Liquid Rotor Resistance.
04/21/2011 9:18 AM
In a resistor grid system, you change resistance for the rotor in steps by shorting out various parts of the grid with contactors or step switches. So the resistance and therefore torque changes are stepped. With a liquid resistor it is infinitely variable, it accomplishes stepless change in torque.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
04/21/2011 11:33 AM
GRR makes lot of noise and vibration during starting especially in HV application.
LRR needs a large space for electrolyte tank but give us a smooth start.
What else?
Anything that can go wrong, will go wrong
Register to Reply 2 comments
