Previous in Forum: Water Tank for Heating/Mixing Biodiesel   Next in Forum: pH in Wet Gas
"Antistatic" Additive
04/22/2011 8:43 AM
I need "antistatic" additive ( rejects smoke and dust ) for transparent top cover polyurethane laquer. I need it to avoid catching smoke and dust on the surface of my applications.
Primus
Pathfinder Tags: antistatic additive
Re: "Antistatic" Additive
04/22/2011 9:04 AM
You're going to have to be more specific. If there are contaminants floating around in the air, they are going to stick to the uncured lacquer, regardless of what you add to it.
Typically the fix for this problem is to apply your coating within a spray booth that incorporates a filtration system.
04/22/2011 11:41 AM
I don't know of an additive for the paint itself. You might try spraying the cured paint with Downey Fabric Softener. That will be temporary at best.
Pink anti-static (ESD) boxes are molded using a soap solution added to the molding compund. I don't know if your PU paint would tolerate some soap, or not. I have no idea how much to recommend if you do try it.
Maybe Mark has an opinion.
04/22/2011 1:19 PM
If it's cured, a box of drier sheets and an occasional wipe down should help stop static cling.
The ingredients in Static Guard are compatible with some finishes, but again, I think the results would be temporary, if it worked at all.
Good Answers: 58
04/23/2011 8:51 AM
A simple approach to static reduction is to raise the relative humidity. Sometimes just a room humidifier to keep RH above 50-60% will solve the problem.
Register to Reply 4 comments
kramarat (2); lyn (1); welderman (1)
