Previous in Forum: Cooling Tower   Next in Forum: Well Pump Failure
10 comments
Good Answers: 15
Help Needed to Derive a Formula
04/25/2011 9:24 AM
I have been trying to size a small gearmotor to drive this machine. The methods I've tried have not given me reasonable answers. Either I have about 10% of the force needed or the result is way too high.
Maybe someone can point me in the right direction. I've probably done something silly and forgot a reaction force or I am just trying to solve the problem the wrong way.
Anyway here are some pictures.
The below picture is an iso.
Since this is proprietary information I've left most of the components off. The gearmotor isn't shown.
I've tried to sum the moments about the center of the gearmotor shaft. I've also summed the vertical forces.
downhill slide to 112 (damn memor.)
Re: Help Needed to Derive a Formula
04/25/2011 10:06 AM
Here' a stab (with a few gross approximations):
Static:
Torques = M x g x d
where M = mass of bridge.
Dynamic:
Average acceleration (lowest point to half-way up),
A = (2 x d)/(t2)
where t is the time to move.
Torqued ≈ (d/2) x M x A
Total Torque = Torques + Torqued
How does that compare with your figures?
Good Answers: 15
04/25/2011 10:14 AM
Thanks John.
I was looking at the static case and hadn't done any calcs with the dynamic. I will absorb this and let you know.
Good Answers: 183
04/25/2011 11:00 AM
You should consider the instant acceleration which is the secdfond derivative of the vertical coordinate z= R*cos(α) with α = ω*t. In the ascending stroke the inertial force adds to the weight.
Friction forces on the columns depend on the friction force between pin and window and thus of the vertical TOTAL load.
If the verical bearings are not preloaded only one column will take the horizontal forces. If the bearing length is small there is a force amplification since the vertical force genrates a moment with respect to the sliding bearing on the carying side.
The model you should use for the analysis is much more complex and there is a risk of blocking if not all factors have been considerd. Be VERY careful.
Best is to make the full model for computation and show it for comments and corrections if required.
Good Answers: 15
04/25/2011 11:23 AM
Nickname,
Thanks. I am starting to understand why my formulas didn't make any sense.
Good Answers: 46
04/25/2011 11:00 AM
Hello, ddk, What your got there is called a Scotch yoke. These links may or may not help but may give you some insight.
K-MODDL great graphics D08 looks like what you want to do.
Scotch yoke
Piston motion equations
and Prototype Fish Robot has a formula that may be the best fit for you to figure out your project. Unlike the piston driving crank.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Good Answers: 15
04/25/2011 11:27 AM
Thanks. Some good sites
Good Answers: 101
04/25/2011 5:31 PM
Free Body Diagrams...
One part at a time...
Slow and steady takes the race...
Measure twice, cut once...
Double check each step before moving to the next free body diagram...
Good Answers: 15
04/26/2011 7:10 AM
Good Answers: 130
04/27/2011 1:54 AM
Might be an idea to have a look at the cranking moment on the lineal bearing, while you're there.
Good Answers: 15
04/27/2011 7:14 AM
thanks,
We're looking at longer bearings for to ensure parallelism.
Register to Reply 10 comments
34point5 (1); ddk (5); JohnDG (1); metalSmiths (1); nick name (1); RVZ717 (1)
