Previous in Forum: pH in Wet Gas   Next in Forum: What Happens If You Adjust the pH of a Sodium Hypochlorite Solution?
India - Member - New Member
Calculating the I D of Ducting
04/27/2011 5:34 AM
Please tell me as to how to calculate the size of the ducting to convey 27000 cubic metre per hour of producer gas at a pressure of 1000 mm WC
Good Answers: 67
Re: Calculating the I D of Ducting
04/28/2011 6:25 AM
It may be piping instead of ducting for producer gas. Check the prescribed velocity from relevant standard, I think its around 10 m/s or 36000 m/hour. Divide volume flow rate by velocity to get cross sectional area of pipe. From this calculate pipe diameter required and select next higher standard size pipe. For your case with 10 m/s velocity, DN1000 pipe is just sufficient.
04/28/2011 7:42 AM
Thank you for the information Mr. Pritam. Can you cite the title of relevant standard and the source for further use?
Good Answers: 67
05/13/2011 4:51 AM
You can refer ASME B31.2-1968 (fuel gas piping). Also IPSS:01-06-014-02 for code of practice.
05/15/2011 11:39 PM
I did refer to the ASME standard, I believe they for home appliances and not for industrial application. Could you give some thumb rules? like the one you said "10 m/s for the velocity" and the size of the pipe as DN 1000.
Good Answers: 67
05/16/2011 5:07 AM
I didn't go through ASME standard. IPSS does not give velocity. But I have seen some tender specification where piping velocity of fuel gases are specified up to 20 m/s. However 15 m/s can be safely followed. For 15 m/s pipe size may reduce to DN 800.
