Previous in Forum: Auto Range Selection of Column Chart by Macro   Next in Forum: Programming an AD7708
HTML Coding Help
04/29/2011 1:01 AM
can any one tell me what does these codes signify in html
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>EMCO</title>
<link href="site.css" type="text/css" rel="stylesheet" />
<script type="text/javascript" language="JavaScript1.2" src="menu/stmenu.js"></script>
<script type="text/javascript" language="JavaScript1.2" src="AC_RunActiveContent.js"></script>
<script type="text/javascript" language="javascript">
function SearchSite()
document.location.href='http://www.emcoindia.com/search.html?cx=002343543654529033385:qxdcrdw2omi&cof=FORID%3A11&ie=UTF-8&q=' + document.getElementById('txtSearch').value + '&sa=Search';
</script>
<script type="text/javascript" language="javascript" src="AC_OETags.js"></script>
<script language="JavaScript" type="text/javascript">
// Globals
// Major version of Flash required
var requiredMajorVersion = 8;
// Minor version of Flash required
var requiredMinorVersion = 0;
var requiredRevision = 0;
RAJU SINGH(DIRECTOR) NEUVO ASYA TECHNO SOLUTION LTD LP
Re: assist me in html
04/29/2011 7:50 AM
Lots of people can, its more than I want to do. Can you explain what you are looking for? Otherwise, I suggest you do some googling or get a book, especially if you are trying to learn.
I'll try to give you a brief start...
In general, all of the stuff within < > is what is called markup. In general, it is intended to tell the target software (like a browser, HTML renderer, or similar) how text not within < > should be displayed.
The DOCTYPE statement specifies the particular standard that the HTML in this document is written to.
04/29/2011 5:59 PM
I checked with my old buddy Wikipedia, and he knows something about this:
HyperText Markup Language
Your answers are contained at the linked article.
Good Answers: 244
04/30/2011 10:02 PM
Though this piece of code is constructed with html (Hyper Text Markup Language), the main functionality is primarily constructed in the calls of css (Cascading Style Sheet) file (site.css) and java script files (stmenu.js, C_RunActiveContent.js and AC_OETags.js) and the java script function (SearchSite).
In addition to html, you need to understand well about the css, xml and java script language and then study the code of the css and java script files for understanding the functionality of this code.
In html, <-- is the starting of the comment and --> is the end of the comment. So, the last 11 lines are commented out and they are not executed.
There are many tutorials available for java script. These links may help:
http://www.cs.brown.edu/courses/bridge/1998/res/javascript/javascript-tutorial.html
http://www.quackit.com/javascript/tutorial/
http://www.w3schools.com/js/
http://www.w3schools.com/css/css_examples.asp
- MS
Register to Reply 3 comments
Doorman (1); msamad (1); rhkramer (1)
