Previous in Forum: ASME B16.47 Series A and B   Next in Forum: Flow Control of Hot Oil System
Welding With/Without Filler Material
05/02/2011 8:03 AM
Hi All,
I just want to know what is the advantage of using welding with filler material as compared to welding without filler material and vice versa. This applies when i want to use Welded SS pipe which is governed by A312 as well as A358.
I know pipe adhering to A312 will be heavier using the same design conditions as compared to A358 as standard A312 uses 12.5% mill tolerance while that A358 uses 0.3mm plate tolerance.
Moreover, after certain size and thickness, welded pipe can not be manufactured using A312 as there are some limitation for pipe welding without filler material.
Thanks.
Re: Welding With/Without Filler Material
05/04/2011 1:18 PM
There are different process for welding without filler material and welding with filler material. ERW (Elect. resistance welding) pipes are generally manufactured not using filler material, while spiral welded pipes are manufactured using filler material. Both the procedures are approved and gives 100% efficiency joints of radiography quality.
05/05/2011 6:04 AM
Thanks Mukesh for your reply.
But i don't reckon you understand the essence of my question. i know what is welding with or without filler material but my question is more than that.
05/05/2011 3:30 PM
Yes you are right. I could not understand the exact essence. I am sorry for that.
ASME section IX gives some explanation as below;
The welding without filler material do have some disadvantages as the chemistry of the moten pool gets changed due to oxidation and other solution reactions of some of the alloying elements and thus the weldment chemistry will be different then the parent metal. By the addition of the proper filler metal in welding, this change in chemistry of the weld metal can be controlled to get the composition of the weld metal approximately same as that of parent metal.
Some procedures do eliminates addition of filler wire by the design of weld in that way and after qualification same is applied for the production purpose.
