Previous in Forum: RTV Potting Compounds   Next in Forum: NACE Pre-Qualified
Good Answers: 125
Swimming Pool Chemistry
05/11/2011 12:22 PM
I converted my pool to saltwater last year. It is time to jump in again finally and I need to correct my water chemistry. I know how to make all required adjustments but am not sure in what order to proceed. My problem areas are TA, CA, and PH. All three are out of whack. TA=200, CA=0, PH=8.6. Any pool experts here that can help me with correction order will be very appreciated.
Good Answers: 29
Re: Swimming Pool Chemistry
05/11/2011 1:20 PM
I always thought saltwater was something you gargle with. Being from Florida you should know this.
05/11/2011 2:02 PM
I'm a dummy, I use this: swimming pool maintenance guide
Good Answers: 109
05/11/2011 10:54 PM
I have not had much to do with salt water pools but was intrigued anyway. You will lower the pH and alkalinity with the addition of muriatic acid. I am not sure what range you should maintain the alkalinity but somewhere in the 100 mg/L range, I think. I just Googled a site that suggested 75-125 mg/L for Alkalinity and that you will need to add 21 oz for each 10 mg of alkalinity/10,000 gallons of water. I take it by CA you mean Ca or calcium. If you are adding sodium salts, the Ca level should be zero. I don't think you want the calcium in pool water unless it is meant to protect some plumbing. Calcium would be difficult to add to the pool (add limestone rocks?).
05/11/2011 11:52 PM
Get the pH right first. Takes a few days to get it down to the 7.2 - 7.4 level you're after.
Mark Taylor, Senior Technical Advisor, CV Bli Tek, Bali, Indonesia.
Good Answers: 125
05/12/2011 3:17 PM
I finally got a pool "expert" to talk to me on the phone. PH first is correct. Next comes CA (cyanuric acid) which needs to be 40-50, and lastly TA (total Alkalinity) which needs to be 80-100.
05/12/2011 4:01 PM
GA PH first - then again after all other adjustments (which could change the PH again).
What is right is not always popular. - What is popular is not always right.
05/12/2011 8:45 AM
I recommend that you post your question on the following web site:
www.troublefreepool.com
They will answer you quickly and they know what they are talking about. They have helped me solve numerous issues with my pool.
Register to Reply 7 comments
kevinm (1); lyn (1); Mike Davis (1); RDGRNR (1); Tamu (1); U NO WHO (1); WJMFIRE (1)
You might be interested in: pH Electrodes, pH Transmitters, pH Instruments
