Previous in Forum: Ethanol Effect on Older Engines   Next in Forum: High Temp Feedthrough
9 comments
Explosion Venting
05/11/2011 3:05 PM
We have to test an explosion vent that has a release pressure of 25lbs/sqft. Each unit has 2 doors and each door has an area of 3' x 10'. These units are nothing more than a door under a great amount of sprung force that is held in place on a trigger plate, 1 trigger per door. When enough pressure (25lbs/sqft) is built up on the doors surface, due to an explosion, the mechanism that pushes the trigger plate will release the door and the spring will assist in keeping the door open. This allows the explosive force to exit the building through the vents without causing damage to the structure.
I have been told that the mechanism should be tested to release at 25lbs of pull force and this will remain constant no matter what the size of the door is. I would think that you would calculate the total sqft of the area of the door and that would be the force required to release the trigger plate. 10x30=300x25=7500lbs but this sounds like a lot of force and what force gauge would messure that amount?
Any ideas would be very helpfull.
Thank you everyone for all your feedback.
Re: Explosion Venting
05/11/2011 3:37 PM
The trigger mechanism can be the same value, regardless of the door size, and so can the area of the trigger initiator because it is the "initiator" and not the actuator.
It doesn't open the door it just lets the mechanism work after the door is open to keep it open. The actuator can be sized according to door weight since the doors will be opened by the blast.
05/12/2011 11:55 AM
I remember a demonstration in 5'th grade involving an empty paint can, votive candle, rubber tube and small amount of flour. Bounced the lid off the cieling. Very impressive and memorable but try doing that today. The kids will be getting their master's by the time you get the permits.
05/11/2011 4:09 PM
I am trying to understand your question fully... The only question you ask is "...what force gauge would messure that amount?" I am not certain this is the real question. Would you consider a few questions from me:
"We have to test an explosion vent that has a release pressure of 25lbs/sqft." Are you an independent certification lab? That is to say, why do you have to do this test?
When you perform this test, what fuel source or combination are you going to use for the deflagration? What... no explosion? I was sort of looking forward to watching that.
Do you have a copy of NFPA 68? Have you read it?
05/12/2011 9:49 AM
Thank you for all the input as it was quite helpful. I am sorry if my question wasn't clear as I am just a laymen, as you might have figured, but the actual question is how do I test this unit if it is claiming to open at 25lbs/sqft. Do I just hook on a force gauge, give it a tug and the door should open with a force of about 25 lbs? We do not have access to an air cannon and there are too many units, 60 in total, that are about 60 feet off the ground on a storage facility to hook up anything from below. We have to maintain the building and we want to make sure that they open as required, for safety and insurance reasons. We could presssurize the building but that seems a little excessive if all we need is a force guage.
05/12/2011 10:08 AM
These expolsion relief vents...
Are the devices a manufactured item? With a manufacturers nameplate, compliance data, date of manufacture, etc. If yes, what does the manufacturer have to say? If no, do you have the original fabrication data and design spec?
I know this is not really your question, but it will be useful to know if the original design was within your required performance today.
05/12/2011 10:59 AM
Do the math from the pressure point of view. 25lbs/sqft=0.17psi or 0.012bar. Very low, but then it doesn't take a large overpressure to damage a building.
25lbs over 3'x10' is 0.833 lbs/sqft = 0.0058psi or 0.0004bar. A good gust of wind could open that panel. What about someone leaning against the door from inside?
25lbs/sqft is a typical explosion vent trigger value, and you will need to test the trigger at 750 lbs for your 30sqft doors.
Look at this link, it talks about a commercial explosion vent and what force would be required to open them. (Scroll down to the last item on the page.)
http://www.c-sgroup.com/explosion-vents/faq
Good Answers: 67
05/13/2011 5:18 AM
Do I just hook on a force gauge, give it a tug and the door should open with a force of about 25 lbs? No, the force unit is lbs/sqft. So, calculate the area of explosion door in sqft and multiply with 25 lbs to get required force to just hook on a force gauge to test. For example if area is 10 sqft, you have to hook 250 lbs. With this calculated load if door is not opening, then its weight is to be reduced. If opens with less load, weight is to be added.
05/12/2011 12:35 AM
You could test them with controlled releases from an air cannon (similar to those seen on Mythbusters) sealed to their housing and with pressure monitors installed.
This would give you control, adjustment, measurability and a realistic scenario.
Good Answers: 181
05/14/2011 3:29 AM
With all my dealings with explosion doors we called the manufacturers in to test them. Simply to get the insurance cover.
After seven explosions in one night, I'm just glad they worked!
Register to Reply 9 comments
Doorman (2); Gazu (1); H2girl (1); lyn (1); meikermann (1); pritam (1); TonyS (1); WAWAUS (1)
