Previous in Forum: Standards for Flushing Old Piping   Next in Forum: Can I Replace SS 304 With Another Material?
Calcualtions Needed for a Hydraulic Motor System
04/11/2007 12:57 PM
How do I calculate a complete hydraulic system to run just an hydraulic motor, with variable speed?
Pathfinder Tags: Hydraulic
Re: Calcualtions Needed for a Hydraulic Motor System
04/11/2007 3:29 PM
That's a short question for a pretty big problem. Start with the no load Rpm and maximum torque required. Then select a hyd motor with the appropriate characteristics. Determine the HP requirement, based on max Rpms rq'd at max torque. Size your power supply accordingly, allowing for system inefficiency. Select a pump with sufficient gpm, an appropriate reservoir for cooling and you're on your way
"A job worth doing, is worth doing well" - My Father
04/12/2007 3:37 AM
Hydraulic Pumps and Motors are hydrostatic components.
The converstion of mechanical torque by means of operating pressure and stroke volume,or vice versa,is the same on all hydrostatic machines.
For torque, this can be seen from the basic formula(without degree of efficiency).
M= ΔP .Vh/2.Π
Pump M= drive torque
Motor M=driven torque(with out η ).
ΔP = Pressure drop between outlet and inlet ,of the pump ,inlet and outlet of the motor
Vh =geometric stroke volume
AWAT
E_mail awatali_3@hotmail.com
04/12/2007 10:09 AM
Any Fluid Power Distributer will design your system for FREE.
They have Sales/Application Engineers who do this all the time.
Get their design and quote and then shop it around for the best price.
Register to Reply 3 comments
AWAT ALI (1); prbarry (1); silver ghost (1)
