Previous in Forum: Gas Turbines Power Plant   Next in Forum: Transmiter Reading Fluctuate
Leakage in Transmiter
05/18/2011 1:46 PM
any body can explain that how we rectify leakage in vacume transmiter tubing?
abdul mateen
Pathfinder Tags: leakage in transmiter
Good Answers: 58
Re: leakage in transmiter
05/18/2011 1:50 PM
I will throw out a wild guess.......replace the tubing?
05/18/2011 2:17 PM
LynDoor™MagicVacTape® will seal those pesky vacuum leaks at only half the cost of re-plumbing.
It comes in a handy-dandy 25 foot roll for just $456.78USD per roll.*
*Guarenteed to stop those pools of vacuum that have been accumulating under the leaks.
Order now:
LynDoorInd.com/stickystuff
* There is a $50.00 fee for translation of the application notes to a language other than Chinese.
India - Member - New Member Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member
Re: Leakage in Transmiter
05/21/2011 2:34 AM
Use Silicon Grease on the ferrules of Impulse line fittings.
SS
05/24/2011 1:51 PM
Replace the vac line tubing, or re ferule your compression fittings...if they snugged down to s*** from over tightening your never going to get a true seal.
cems
05/28/2011 5:32 PM
Check the tubing connectors specially ferrules.Mostly problem when ferrule becomes over tighting.Use the silicaon or sealing fluid on joints.
cems (1); jamsshed (1); KJK/USA (1); lyn (1); singh605 (1)
You might be interested in: Plastic Tubing, Rubber Tubing, Tubing
