Previous in Forum: Electronic Pressure Sensors   Next in Forum: Testing Volume
Open Loop Gain
05/19/2011 1:59 PM
what is open loop gain in Op Amp
abdul mateen
Pathfinder Tags: open loop gain
Re: open loop gain
05/19/2011 2:28 PM
I assume you're asking for a reason, and we could probably give a better answer if we knew the reason.
But, I'll make an attempt. An op amp is an (operational) amplifier. It will allow you to input a signal of a given level and get a signal of a higher level out. The ratio of the output signal to the input signal is the gain. I think it is most often a voltage gain, but it could also be a current gain.
In an amplifier you can have a feedback loop, whereby part of the output is fed back to the input. In general, this is done to increase the stability of the amplifier. If the amplifier is unstable, you can get effects like oscillation or distortion.
When a feedback loop is present, the gain measured then is called closed loop gain.
When a feedback loop is not present, the gain measured is called open loop gain.
You should try looking some of these terms up on the Internet, using google. I'll bet Wikipedia, has a pretty good article on op amps, open loop gain, closed loop gain, and similar. I'll bet you can find some good answers with pictures and such.
Good Answers: 101
Re: open loop gain
05/19/2011 2:29 PM
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: open loop gain
09/03/2011 9:58 PM
Awesome reply -- you made my day, and my "Delicious.com" account just got a new link added to it!
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Re: open loop gain
05/19/2011 6:29 PM
There is also some key things that the open loop gain of an op-amp tells a circuit designer. The easiest thing that one realizes is that since an op-amp does actually have a finite gain, the first order calculations and rules of thumb of amplifier gain are not precisely correct. For example, in the inverting amplifier configuration there are actual signal voltages on the inverting node of the op-amp. They are very tiny voltages but they are still there. This virtual ground node will not really be at ground potential.
This parameter is but one of many real versus ideal parameters one should understand of an op-amp.
Re: Open Loop Gain
05/23/2011 7:37 AM
about 100,000
engineertony (1); redfred (1); rhkramer (1); RVZ717 (1); tonykuphaldt (1)
