Previous in Forum: Refrigerator   Next in Forum: AUTOCAD 2007 3D TO 2D
Manager
05/21/2011 6:14 AM
Dear All
I have a condensing turbine having the input pressure of 65 kg, and generator of 5.5MW, as this is condensing turbine and i need the exhaust pressure of 1.6 kg, so can any one tell me that is it possible to get the exhaust pressure with condensation turbine, if yes than how please confirm
Re: Manager
05/22/2011 11:09 AM
You can but not recommended due to excessive exhaust temperatures. At best the 1.6 kg you indicate is 1.6 kg/cm2 absolute which surpassed vacuum. In order to achieve condensation the exhaust temperature must be lower than 128.5 deg. C which seems to me much higher than normal exhaust temperatures of condensing turbines I have come across (ca. 45 ~ 55 deg. C). The manual or tag plate may indicate the permissible exhaust temperate and pressures. Kind regards, R. Doest
Re: Manager
05/22/2011 3:03 PM
Dear Mr.ianizamani:
Pl. furnish full details such as, Quantity of steam to be extracted, power loss due to extraction at 1.6 Kg. acceptable or not, details of turbine such as vaccuum, steam for ejector, - whether provision is there or not, if so what is the turbine manufacturers data.
rajeswari.
Re: Manager
05/24/2011 12:51 PM
I fully agree with rdoest. At 1.6 kg absolue pressure, exhaust temperature will be too high for condensation. Normal exhaust temperature for such turbines is 50 degree C and exhust pressure is 0.2 absolute.
Register to Reply 3 comments
Mukesh0861 (1); rajeswari (1); rdoest (1)
