Previous in Forum: Star - Delta Transformer Protection   Next in Forum: Transformer
Momentary Overload of Inverters
05/30/2011 4:01 AM
how much is the momentary overload & its withstand time ...?
Good Answers: 181
Re: Momentary overload of Inverters
05/30/2011 5:28 AM
Contact the manufacturers.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Construction Engineering - New Member
05/30/2011 12:07 PM
160 percent of loading current or more. Time is from 0 second to hours... You are the one to coordinate it, mate.
Anything that can go wrong, will go wrong
Good Answers: 804
05/31/2011 11:32 AM
Depends on the manufacturer, depends on the model. No way to answer that.
Good Answers: 804
Re: Momentary Overload of Inverters
05/31/2011 12:01 PM
Too late to append:
For example a "Constant Torque" rated drive will typically be 150% for 60 seconds, but a 'Variable Torque" rated drive of the same output power might only be rated for 110% for 30 seconds. Even those values differ from one mfr to another, and some don't use the terms Constant and Variable Torque, choosing instead to say something like Heavy Duty and Light Duty etc. etc.
Register to Reply 4 comments
hien.nguyenquoc (1); JRaef (2); TonyS (1)
