Previous in Forum: Condition Monitoring, Partial Discharge Monitoring   Next in Forum: DIY Battery Packs with Multiple Taps - Charging
8 comments
Corona Discharge
06/04/2011 8:17 AM
how can we eliminate corona discharge on insulators? can dust contaminants result to this phenomena?
Pathfinder Tags: corona discharge
Re: corona discharge
06/04/2011 8:24 AM
Never heard of corona on insulators.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
06/04/2011 8:44 AM
Breakdown of insulators on power lines is a problem many utilities have. This can lead to power interruptions and early replacement of parts. The breakdown can be attributed to localized discharges called corona.
Corona can be defined as a type of localized discharge that results from high, non-uniform electric fields. It causes deterioration of the insulator and sometimes causes complete breakdown. Proper design can reduce how often corona occurs, thus creating better protection and longer life of the insulator.
Corona can be detected in a number of ways. The obvious ways are by sight and sound. At high voltages, corona produces visible light, and audible noise. Corona can also be detected by using various types of measuring equipment. When observed, corona may first appear as a faint glow. As the current and potential are increased the glow spreads eventually producing streamers. The glow may have a paintbrush like appearance. The audible noise that corona causes can be described as crackling or hissing sounds. The noise is caused by explosion gas expansions. The visible light and audible noise can be observed simultaneously.
Dust contaminants increases the level of Corona Discharge.
The voltage at which corona begins in called the discharge inception voltage. Conversely, the voltage at which corona ceases is called discharge extinction Voltage. Finally, using the partial discharge detector, the actual charge, q, of the corona can be obtained.
May this will clarify your doubt.
Vinu_Answers Sure_Answers
Sure Answers Always
06/05/2011 7:50 PM
thank you sir..im a little bit enlightened about this
Good Answers: 181
Re: Corona Discharge
06/04/2011 1:35 PM
Contaminants on insulators are more likely to cause tracking, the sound is quite distinctive. During damp weather you can hear the crackling sound build up and if it's dark a distinct arc tracking across the surface of the pot can be seen. The whole idea of OH line insulators is rain will wash them clean, damp weather is the enemy.
To be honest I've never come across corona discharge on OH lines I've worked on.
Good Answers: 11
06/04/2011 1:53 PM
Some power companies wash their insulators with deionized water. They leave the power on and probably ground the tank holding the deionized water. The water is only slightly conductive so there is no high current.
There is also a special silicon grease that some power companies put on their insulators to reduce corona.
Good Answers: 181
06/04/2011 2:47 PM
On a visit to Drakelow A & C stations as an apprentice I watched guys in the switch yard pressure washing insulators, I jokingly said to the guide wouldn't fancy doing that live…… They were!
Apparently they rely on the air gap between each drop and the low conductivity of the ionised water as you say.
I'd take some bloody convincing to do it!
Good Answers: 131
06/06/2011 2:42 PM
Actually, it's not a grease, but rather more of a polish or wax. It helps remove surface contaminants, and then is buffed to a smooth shine that helps prevent contaminants from sticking as easily afterward.
In areas that have problems with water spray freezing on insulators (such as near cooling towers or in areas of frequent freezing rain / sleet), I have heard of a company that uses ground up walnut shells power blasted by CO2 to clean off the ice & sleet. It's a relatively good insulating mix, so no problems with flashover. They use it even at fairly high transmission voltages (345kV).
Anonymous Poster #2
06/06/2011 2:31 PM
submerge in oil? Not sure the size or scale you are asking about, but the point of breakdown in oil is greater than that of air.
Register to Reply 8 comments
Anonymous Poster (2); Carl Pugh (1); PeterT (1); prometu (1); TonyS (2); Vinu_Answers (1)
