Previous in Forum: Feed Forward Control Loop   Next in Forum: Weighing Scale
Touch Screen Panel PC's
06/10/2011 12:29 PM
Anyone have any experience with any fairly economical priced panel mount industrial touch screen pc's that are fairly light? Less then 3 lbs preferably. I've been finding so many I just wanted to see if anyone had any actual hands on experience with certain brands/types and could recommended one.
Thanks guys
cems
Good Answers: 29
Re: Touch Screen Panel PC's
06/10/2011 12:50 PM
I don't have much of an idea what you're trying to accomplish but I've had lots of luck with these.
Good Answers: 804
06/11/2011 1:39 PM
Not even scratching the surface of enough information. You say the weight, but how large of a screen? Do you want an entire PC, or an optimized HMI to run a lean program of some sort? Is it going to communicate to external devices or stand alone?
Good Answers: 176
06/11/2011 2:24 PM
Advantech, made is Asia, typical Asian/English issues with documentation, a PC is a PC. They're custom made and on occasion don't come through with the option ordered and you have to go through the hassle of making it right.
http://www.advantech.com/applied-computing-systems/panel-pc/
06/22/2011 11:44 AM
When I was working in the bakery we were replacing the Allen-Bradley panels with panels from Automation Direct.
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
06/22/2011 3:23 PM
Ok, Well to be a little more specific this doesn't need to be anything too fancy. It will only require to run a windows operating system be it embeded or xp, doesn't matter as long as it can run Java Applets. This computer is a basic HMI that will connect to a Java applet over ethernet to an IP which will give a display and control for an HMI on the front of a rack.
cems
04/23/2019 2:49 AM
If you want to buy your own HMI by purchasing accessories yourself? All accessories can be purchased at VICPAS HMI Parts.
VICAPS HMI Parts Center: Touchscreen-Keypad-LCD Displya-Protective Film
Register to Reply 6 comments
cems (1); Coldspot (1); Iris (1); JRaef (1); RDGRNR (1); VICAPS HMI Parts (1)
