Previous in Forum: Perkin Engine Problems   Next in Forum: Lux Level
Axial Compressor
06/11/2011 5:19 AM
I am trying to write a computer code in fortran 90 for an axial compressor of a turbo jet engine. I am facing a problem that is of only having two inputs:
1.compressor pressure ratio
2. compressor inlet diameter
Help me out by giving different mathematical expressions to calculate rpm, blade angles, air angles, pressure and temperature after every stage.
Re: Axial Compressor
06/11/2011 9:41 AM
Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
06/12/2011 12:11 AM
Please refer any of good thermodynamics or power plant engineering or Mechanical engineering hand books, you will get all relevant formula. Sometime Fortran code may be also available. Best Wishes.
Good Answers: 54
06/13/2011 6:54 PM
Fortran90?
Is that still used in the real world?
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Register to Reply 3 comments
ffej (1); lyn (1); mrswamy (1)
