Previous in Forum: Expansion Valve   Next in Forum: PWHT for SS321 Material
Proportion Between Ra and Profile on Steel (Sandblasting)
06/13/2011 12:35 AM
when you use the digital device to calculate profile of sandblasting on steel most of them work on base of Ra and Rz
is there any formula for proportion Between Ra and profile (mils)?
Re: proportion Between Ra and profile on steel (Sandblasting)
06/13/2011 1:27 AM
By profile do you mean peak to peak?
Rz is the average peak to peak.
Check whether this article or this helps.
Please note that these all are basically statistical (and that has to be obviously) after all you are doiing all your measurements over a small sample of the total surface (linear traverse of the pick-up and that too over a few millimeters cut-off length).
