Previous in Forum: Embossed Jacket.   Next in Forum: Failure of Coil
Tensile Strength
06/14/2011 5:38 AM
Tensile strength is as important as other material characteristics according to what purpose is. Some materials which have regular range of tensile strength can change their own characteristics using any means such as heat treatment? If possible, how can the ferrous material change the hardness? I mean, identical material can change the hardness or tensile strength? Assuming that the tensile strength become lower, hardness value also can be lower?
Please give me good advice. Thanks all good luck.
Re: Tensile strength
06/14/2011 6:46 AM
In ferrous materials mild carbon steel of <0.25% carbon does not exhibit any significant change in the tensile strength whereas materials of higher carbon content exhibit increased tensile strength by heating & quenching. The metallurgical change of grain structure from Austenite region results in ferritic and pearlitic structure (with alternate stripes of Ferrite and Cementite) in slow cooling but results in martensitic structure during quenching. Here carbon atoms are trapped while migrating to a stable structure which causes the increase in tensile strength. Increase in tensile strength causes proportionate increase in hardness value.
The effect is akin to when a bundle of bamboo sticks are kept arranged in an orderly stack it is easy to pull out one of them, while it is much more difficult to pull out one from a bundle that is randomly laid bunched together interlocked in all directions.
Re: Tensile Strength
06/14/2011 9:06 AM
It is basics of metallurgy and heattreatment. I would rather that you go through some good physical metallurgy books. The theory will be quite elaborate and would start from the lattice to grain structure phase diagrams....
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
06/15/2011 4:35 AM
On most materials, tensile strength and hardness go parallel: If you make some heat treatment (or mechanical such us cold forming) use to modify both in the same direction, both increase or decrease, but If you are not quite expert on the matter, I would recommend you to select a standardized treatment and do not play with that as some other important properties are also involved (i.e toughness).
Kind regards
Register to Reply 3 comments
Anonymous Poster (1); kasharma (1); Kwetz (1)
You might be interested in: Hardness Testers, Linear Shafts, Rotary Shafts
