Previous in Forum: Workshop Set Up   Next in Forum: Air Handling Unit Noise Attenuation
Suitable material for gears in gear pump
06/15/2011 7:32 AM
Hi frnds..
We use gear pumps in extruder for polymer yarn production
The melted yarn passed through the mested gears (drive and driven gears).The inlet pressure is less than outlet pressure. While processing the Spur gears 26 Teeth are get damaged or worn out quickly.
1.So pls suggest which material is suitable for gears among these EN353, EN24, SAE8620
2. Is helical gears more efficient to produce more outlet pressure than spur gears?
Good Answers: 183
Re: Suitable material for gears in gear pump
06/15/2011 6:45 PM
It would be of help to send some picture of the worn gears in order to see where and how they wear. Do you have any knowledge about the pressure ?
Good Answers: 181
06/17/2011 2:12 AM
I may be wrong but I don't think helical gears will work in a pump.
Good Answers: 48
06/17/2011 4:10 AM
Helical gears are commonly used in external gear pumps. Some of the benefits are reduced noise, reduced loading on the teeth, reduced pulsation, etc. The downside compared to spur gears is that they produce axial loading, and there can be some sliding friction on the teeth. There are also double helical gears, aka herringbone or v-shape, which eliminate the axial loading, but are much more difficult to manufacture. I could be wrong, but I don't think helical gears are any more efficient at producing pressure.
Maag (Textron), Witte and Zenith are three of the top manufacturers of polymer gear pumps. Between them they use spur, helical and herringbone gears. The gear material is commonly tool steel or other special heat-treated, nitrided or hard-coated steels. I am not familiar enough with this process, these pumps or these materials to give advice on material selection. It might be best to contact one of the above, or another manufacturer of polymer gear pumps for advice.
Register to Reply 3 comments
Holzfeller (1); nick name (1); TonyS (1)
You might be interested in: Spur Gears, Metric Gears, Gears
