I have a C15 in a freightliner about 6 months ago i started loosing fuel milage sence I have replaced ecm wire harness injectors with new not remans cups changed to cat fuel filter all sensors check out no codes and have dyno tested. it has been overfueling produceing more power and im loosing fuel millage. this is a 6.5 mpg truck on a year average and i have been running between 3.2 to 5.8 only empty and very good weather conditions can i get over 6 mpg i have also replaced the balancer and had the oil seals and gaskets replaced on front of engine evant went with lower resistance rolling tires when driveing down the road it acts like it has a poer loss and has a slight vibration like it is not fiering on all pistons,the harder the pull the wors it gets. It also when hot has a starting problem, it will lock up like loading with fuel when relaxing key will then turn and start fine Thank you for any help or sugestion you can pass on to me ...Donald
