Previous in Forum: Tip modification and Tip diameter(gear manufacture)   Next in Forum: VSD on Hydr Power Pack
Machining Polycorbaonate Sheet
06/16/2011 9:38 AM
I am making something by milling the polycorbonate transperent sheet. There are some machining marks . how can remove them
Good Answers: 299
Re: machining polycorbaonate sheet
06/16/2011 9:43 AM
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: Machining Polycarbonate Sheet
06/16/2011 2:12 PM
Some people have used a butane torch to flame polish machining marks out of polycarbs. But this is a skill that is difficult to master, as it will quickly burn black or blister if your timing and technique is not perfected. You could practice on scrap first, but it's risky. It is more commonly used on acrylic.
Solvent polishing after fine sanding can often give you excellent results on polycarb.
Re: Machining Polycorbaonate Sheet
06/16/2011 5:44 PM
I might be tempted to buff them out with a buffing wheel. After sanding, if required.
I have misgivings about using solvents on PC. If the solvent is strong enough to dissolve the PC, it may also induce stress cracks along the edge, since the machining may have partially relieved the molded in stress associated with producing the sheet.
Maybe Out of Box Experience has a specific solvent/process in mind?
Good Answers: 39
06/16/2011 6:48 PM
I have completely removed machining marks and got a clear finish by hand lapping the surface, using a surface plate and very fine polishing sheets. But this only works if the surface to be polished is flat.
As far as solvent polishing, the solvent used is Methylene Chloride (not to be confused with MEK). Absolutely do this in a well ventilated area... like with a fan blowing on you. Don't breathe the stuff, and wear gloves to keep it from your skin. Incidental contact won't instantly rot your skin, but it should be avoided. After getting the surface as smooth as possible with mechanical methods, dip a corner of a lint free cloth into it and rub the surface to be polished. Continue until it's clear. Don't let it drip. Crazing may result if you try to remove marks that are heavy, but if you pre-polish as best you can and use this method as the final touch to clear up the cloudiness, you can get beautiful results. If you are worried about crazing or cracks, and you have the time... do one part, or a scrap part, and them wait about 72 hours. Any crazing that will happen, will happen in that time frame.
Practice on scrap until you get the technique right.
Vapor polishing is the best way to do what you're trying to achieve, and there are ways to DIY, but I wouldn't attempt it. If it's worth it to you, OP... find a local vapor polisher, or have it sent out. Your part will come back crystal clear. It's basically same as solvent polish, but the solvent is heated inside a small chamber and the vapors do the work.
Doorman (1); lyn (1); Out of Box Experience (2)
