Previous in Forum: Standard for Calibration of Temperature Indicator   Next in Forum: Asking for Information on a Company
India - Member - B.E (MECHANICAL), M.E (appeared) Engineering Fields - Mechanical Engineering - New Member Technical Fields - Education - New Member
Plotting A Graph
06/17/2011 5:52 AM
hi all...
i have some test results with me.
i tested one job for vibration testing at different 8 points.
every time i attached an accelerometer to one point and took a frequency sweep of 10- 80 Hz.
i got values of acceleration at 510 instances for 10- 80 hz.
I want graph of 'g' level Vs frequency.
but excel is giving me graph of 'g' level Vs instances... ie it is plotting 1-510 on x axis instead of 10-80...
eg:my values are
FREQUENCYpoint 1
X Unit(Hz)Y Unit(gn)
X ValueY Value(Mag)
101.001883583
10.040776480.99476612
10.081719240.995766799
10.122828940.995167559
10.164106280.995450647
10.205551930.995657396
10.247166580.994743851
10.288950920.994969174
10.330905640.995580278
10.373031440.996990565
10.415329020.996006418
10.457799060.996843332
10.500442290.997854805
10.54325940.998303798
10.58625110.998081003
10.629418110.99851113
10.672761140.99745959
please help me..
Re: plotting a graph
06/17/2011 6:20 AM
Select the data, then use the chart wizard and select X-Y (scatter), with joined-up lines, thus:
There's the result:
I left off all the fancy titles etc., but you should get the idea.
