Previous in Forum: Durability Of Plastic   Next in Forum: Is It Dangerous to Try and Move Chlorine Bucket?
fire mechanism
06/18/2011 1:21 PM
i want to know the mechanism of reaction about action of the fluorine radical on the chain reaction of a flame???? with regard of FM200.
Re: fire mechanism
06/18/2011 2:57 PM
Enroll in a class at the local university.
Good Answers: 125
Re: fire mechanism
06/20/2011 12:16 PM
Heptafluoropropane (FM-200) suppresses fire by both physical and chemical means. When you say "reaction" I assume you are referring to the "chain breaking" ability of this compound. It does indeed break the chain of combustion, and hence the demise of the fire triangle and the birth of the fire tetrahedron years ago.
Re: fire mechanism
06/20/2011 2:15 PM
yes i mean chain breaking............and i need the equation for free radical that used in the reaction .
Good Answers: 125
Re: fire mechanism
06/20/2011 3:11 PM
I don't know what you mean by "I need the equation". The combustion process is not fully understood. Neither is the process by which chain breaking occurs. The most likely theory is that oxygen must be "activated" for use by the fire. The cross section, however, of the fluorine molecule is large enough to capture the electrons created during the ionization of hydro-carbon molecules that would otherwise create O2 for combustion, thereby inhibiting the combustion process. There certainly is no equation for any of this theoretical shtuff.
Register to Reply 4 comments
lyn (1); pepsi9 (1); WJMFIRE (2)
