Previous in Forum: Nitrile Rubber Sleeves Cutting   Next in Forum: PVC Pipe Installation
Uses of 1 Ton Per Hour Capacity Ball Mill
06/22/2011 2:25 AM
I am having 1 ton per hour grinding capacity ball mill recently this 2 chamber ball mill is used as cement grinding mill. I want to use this ball mill for producing other products. Kindly suggest.
Re: Uses of 1 Ton Per Hour Capacity Ball Mill
06/22/2011 10:35 AM
I don't recommend using a mill that previously produced concrete to make anything that makes food, like grinding flour. Other than that you have to look at what raw materials you have in your area that requires large bulk grinding to make a usable product. You also have to look at your potential customers and what ground products they may want. These are business concerns though, not engineering concerns. Since this is a business, money should be transferred for services rendered. Are you willing to pay for a consultant to tell you how to grow your business?
Good Answers: 53
06/22/2011 4:26 PM
Fertilizer.
Good Answers: 120
06/23/2011 4:58 AM
Ball mills can be used to crush any brittle material. The maker will advise what other uses it can be put to.
The grinding energy
and grinding coefficient should be studied.
Per Ardua Ad Astra
Good Answers: 181
07/04/2011 6:18 AM
Why have you bought the ball mill?
02/08/2016 4:30 PM
you might be interested in
3 easy steps to calculate ball mill capacity (from Strommashina Corp. )
Your company has bought a ball mill and now you would like to know what performance to expect from it?
You are going to buy an expensive ball mill and now would like to know what profitability to expect from it?
You need to process (grind) a certain mineral and would like to choose the most efficient model of a ball mill?
We can help you with these issues! Let us present an easy and convenient service for calculating ball mill capacity.
02/08/2016 4:59 PM
Clearly you are punctual and highly observant. What more could anyone want from an opportunist!
Register to Reply 6 comments
Ace Boeringa (1); aurizon (1); redfred (2); Strommashina (1); TonyS (1)
