Previous in Forum: how to make globalspec.com list my company   Next in Forum: How to Grow Under a LED Light
calculation
06/22/2011 3:09 AM
to calculate the weight of angles eg: i have width , height , thickness and the length in mm,......... what formula can be used 2 calculate the weight
Re: calculation
06/24/2011 11:21 AM
If you have width, height, thickness and the length in mm, then you have the total volume. Multiply this volume of material by the density, and you will have the weight of the piece.
Volume * Density
Good Answers: 67
Re: calculation
06/27/2011 12:03 PM
Refer any steel table. For any standard angle size you can directly get weight per meter length.
Re: calculation
06/28/2011 12:25 AM
guys ............this is not what im looking for .........it seems youll have not got it ....just an example...... if u need to calcukate the weight of flatbar.... what is the formula to calculate it ...simple ....Width x Thickness X Lenght X .00785 gives youthe weight per pc.
Same if u have C section like 125 x 65 x 6mts length ....i need to know how to calculate the weight ....i need an simple answer.
Good Answers: 67
Re: calculation
06/28/2011 12:56 AM
This is not the forum for doing your simple home work. Go through some geometry text books and get the answer.
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: calculation
06/30/2011 4:07 AM
That's not how this forum works, maxi. And I can assure you that aside from the help that the other posters just graciously tried to give you... this post of mine will be the kindest words you see from this point forward, from the rest of the members.
Doorman (1); maxi (1); Out of Box Experience (1); pritam (2)
