Previous in Forum: Difference Between Pumps and Compressors   Next in Forum: Designing A Cantilever Platform Using Epoxy-Glass Fiber
8 comments
About Mode of Heat Transfer
06/24/2011 6:41 AM
Dear Friends,
One small clarification....
If Heat generated in copper wire & it transfer through insulation paper, silicon steel core & finally reaches Housing means (No gap or No air present between Copper wire, Insulation paper, Silicon steel core & Housing),
Is this Conduction heat transfer or Convection heat transfer?
With regards,
Amith Raj.N
Re: About Mode of Heat Transfer
06/24/2011 6:58 AM
Hi,
This is conduction.
Just a small explanation. Convection is mainly when there is a movement of fluid over a stationary or another moving object. Here, there is no movement. So this is conduction
06/24/2011 7:49 AM
Conduction heat trasfer
aegeannavigator@hotmail.com
06/24/2011 9:37 AM
It is Conduction.
Conduction is the movement of heat on a particle to particle level. Like how a spoon become hot when it is placed in a cup of hot coffee.
Convection is the heat transfer via a medium such as air or water.
See here for better explination.
The early bird may get the worm, but the second mouse get's the cheese.
Good Answers: 88
06/24/2011 2:10 PM
Heat transfer to where? Unless you have this scheme in a vacum ther's also some convection heat transfer and unless you have it surrounded by totally reflective survace there will be some heat radiated. S.M.
Good Answers: 101
06/24/2011 6:13 PM
In reality, you will have small amounts of all three, Convection, conduction and radiation. If running calculations for heat transfer it's most likely ok to assume conduction as the main method of heat transfer, however there will be small amounts of heat being transferred by convection and radiation. You don't necessarily need fluid/air movement from external sources to have convection, as the heat itself will cause the air to move. Just thought I'd try and complicate things a bit more...
Conduction is your primary source.
Good Answers: 120
06/24/2011 10:29 PM
Is this homework transfer? From you to us?
Per Ardua Ad Astra
06/25/2011 12:16 PM
Motors need convection or it will burn for that reason commonly have a fan or are open.Transformers are open or have some metalic sink to remove heat by convection (black painted adds radation).just very little power devices could trust in conduction.-
Good Answers: 120
06/25/2011 12:26 PM
Modern industrial motors have a classification called TEFC, are totally enclosed fan cooled for fire reasons, and dust reasons and they have internal fans and external radiating fins over which air is blown to cool them. Other categories are
categories of motors
TEFC
Per Ardua Ad Astra
AegeanNavigator (1); aurizon (2); dcpppf (1); ferquiza (1); Raam (1); RVZ717 (1); SimpleMind (1)
