Previous in Forum: Leuze MSI 100 Safety Relay   Next in Forum: Numbers are Missing in the Digital Clock
8 comments
50hz Instrument Connect to 60hz Supply
06/24/2011 8:22 AM
I have 3 nos of instruments they are operated as 700w/110v/1ph/60hz , but my main supply is 110v/1ph/50hz , can you please let me know that if i connect to this 50hz cycle will there me any damage of my instruments ,Please do let me know waiting for your reply.
Re: 50hz instrument connect to 60hz supply....
06/24/2011 8:28 AM
what instrument is that?
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
06/24/2011 8:37 AM
well Mr.Bravo it is pH , Conducitivity Instrument that it my clarification is only can i connect to 50hz supply as the instrument is 60hz
06/24/2011 9:04 AM
In all likelihood, not a problem, since tPreview Commenthe design of this meter will not be affected by freq.
Good Answers: 29
06/24/2011 8:42 AM
Check with the manufacturer regarding input power requirements.
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
06/24/2011 8:45 AM
As a general rule it may be unsafe to operate 60Hz rated appliances at 50Hz supply frequency. Most of the 60Hz equipments are not build for running permanently on 50Hz. But can be operated for some time. You would loose 20% in speed (if your equipment is motor). Operating 60Hz appliances at 50Hz may result in excessive heat build up in transformers or in certain types of electric motors (because of too little iron in the core of transformer and inductor to get the same impedance).
Possible solutions: Frequency converter
Also, refer link below:
http://www.armory.com/~stacey/frequency-50.html
This link will help you to find out suitable answers
Vinu_Answers Sure_answers
Sure Answers Always
06/24/2011 8:56 AM
I understand that you want to connect 60Hz instrument to 50 Hz source. And your equipment are not using input frequency Or performance ( as said by Vinu_answer) as basis of manipulation internally hence I would suggest that you may connect to 50Hz. However, most of elevtronic equipments can operate now a days on both frequencies.
Engineering is an APPLICATION..
Re: 50hz Instrument Connect to 60hz Supply
06/24/2011 10:10 AM
Yes, most instruments now days are compatible with 50 or 60hz. If you want to be sure, you could buy a 50-60hz converter. Either way I'd rifle through some of these results, maybe you'll come across something more helpful than this post
The early bird may get the worm, but the second mouse get's the cheese.
Good Answers: 117
06/24/2011 11:10 PM
what does the the label on the machine/handbook say?
Register to Reply 8 comments
bravo88 (2); brich (1); dcpppf (1); RDGRNR (1); Salunkhem (1); samsam_sam45 (1); Vinu_Answers (1)
