Previous in Forum: Oil for Phosphor Bronze   Next in Forum: Boiler Design
Efficiency Of Ahu
06/26/2011 6:15 AM
How to compute the actual efficiency of ahu?
Tanx
Good Answers: 181
Re: efficiency of ahu
06/26/2011 8:14 AM
Ask the Administrasi Hukum Umum (Indonesian: General Legal Administration) they'll tell you
06/26/2011 9:34 AM
The same way you calculate any efficiency!
100% ahu out / ahu in
Good Answers: 46
Re: Efficiency Of Ahu
06/27/2011 12:13 AM
Ok, ahu = air handler unit? Air temp in, air temp out, air flow rate verses temp of the heating/cooling unit located in it.
I know there more to this, I just did not want to get the books out and do the homework.
Also Google AHU Efficiency.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
Good Answers: 67
06/27/2011 6:16 AM
Main function of ahu is non contact heat transfer from air to chilled water (for cooling). You should have a 'standard value of heat transfer rate' at standard operating conditions like chilled water inlet temp, chilled water flow rate, air flow rate inlet temp & relative humidity etc. Now with similar conditions calculate the heat transfer rate and divide it by 'standard value of heat transfer rate' to get ahu efficiency.
In ahu's the main reasons causing efficiency loss are clogging of water tubes and dust deposits on fins surface on air side. If you have reliable digital temperature gages for chilled water inlet & outlet and water flow rate measurement, you can easily calculate heat transfer rate. If other parameter like air flow rate & inlet temp, water flow rate & inlet temp are same as standard calculation then ahu efficiency is approximately equal to the following ratio of chilled water differential temp:
ahu efficiency = delta T(actual)/ delta T(standard)
07/04/2011 7:31 AM
AHU efficiency =deltaTactual/deltaTstandard of manufacturer
AHU efficiency largely depends on level of cleanliness of coils & filters, coil design giving air bypass factor, slip of belt
Geon Melek Zahir Ahsan (1); metalSmiths (1); pritam (1); redfred (1); TonyS (1)
