Previous in Forum: Touch Screen Displays for Micrologix 1400   Next in Forum: theory of 4 to 20ma
g’s
06/29/2011 5:35 AM
Hi every one!
please tell me what is this engineering unit? "g's"
Best regards!
Re: g’s
06/29/2011 5:51 AM
gram (gramme) or the acceleration due to gravity, it would help if you gave the context.
Or the first letter of Google?
Good Answers: 67
Re: g’s
06/29/2011 5:59 AM
You should have given more detail about it, where you have encountered.
The notation "g" is for acceleration due to gravity on Earth and is equal to approx. 9.8 m/s2. So, any acceleration can be expressed in the unit "g". For example acceleration of value 98 m/s2 can also be expressed as 10 g's. But it is normally used to compare the acceleration due to gravity on other heavenly bodies like Moon or Jupiter to compare with that of Earth. It is much similar to expressing the distance of planets from Sun in Astronomical Units (AU) which is nothing but average distance of Earth from Sun.
Re: g’s
06/29/2011 7:09 PM
Taken from:Units: G
g
a symbol for the average acceleration produced by gravity at the Earth's surface (sea level). The actual acceleration of gravity varies from place to place, depending on latitude, altitude, and local geology. The symbol g is often used informally as a unit of acceleration. By agreement among physicists, the standard acceleration of gravity gn is defined to be exactly 9.806 65 meters per second per second (m/s2), or about 32.174 05 feet per second per second. At latitude p, a conventional value of the acceleration of gravity at sea level is given by the International Gravity Formula,
g(p)=9.7803267714(1+0.00193185138639sin2(p))/√(1-0.0069437999013sin2(p)). The variation, caused by the oblateness of the Earth and the accleration we experience due to the rotation of the Earth, is about half a percent, from 9.780 327 m/s2 at the Equator to 9.833 421 m/s2 at the poles. The symbol g was used as a unit first in aeronautical and space engineering, where it is important to limit the accelerations experienced by the crew members of aircraft and spaceships: the "g forces," as they are called. This use became familiar through the space programs, and now a variety of accelerations are measured in g's. The names gee and grav is also used for this unit. Note that g is also the symbol for the gram.
Re: g’s
07/08/2011 1:10 PM
Dear Askaripour,
"g" refers to gravitationa effect- relates to while in motion.
For example - Astronauts experience this 'g' effect while ascending during launching of a satellite, where the VELOCITY is built up from zero KM/Sec. initially to 11.2 KM/Sec to 13 KM/sec in a span 200 to 400 Seconds which is fantastic build up of velocity or speed working out to 40,320 KM/Hr. to 46,800 KM/Hr., makes to feel 'g'.
This velocity is called ESCAPE VELOCITY with out attaining this velocity satellite cannot cross the earth's gravitational limit while proceeding to moon or other planet.
At this speed the vertical component of ascending will be against Earth's gravity and max subjected to 6 times of gravity referred as "6g"
Some time we can experience the above referred effect in a lft which starts quickly.
Thanks.
Rajeswari,
Good Answers: 67
Re: g’s
07/09/2011 1:26 AM
GA.
lyn (1); pritam (2); rajeswari (1); user-deleted-1105 (1)
