Previous in Forum: how to connect printer to the c program output ?   Next in Forum: FANUC 10M Parameters Wanted
programming
06/29/2011 9:22 AM
how to edit .Dll and .EXE file
Re: programming
06/29/2011 9:34 AM
Looks like there are a lot of programs out there to aid you in your quest...
The early bird may get the worm, but the second mouse get's the cheese.
Re: programming
06/29/2011 9:45 AM
You can only do this from the source code. Some compilers can reverse compile these files into source code but often weird hidden and confusing things can happen if you happen to choose the wrong programming language to translate these codes into source code. Anybody who has tried to follow a recursive LISP program by reading a C++ version of the source code knows what I'm saying.
The added problem of reverse engineering these codes is that these files do not have any of the documentation (remarks, notes) that the original programmer inserted to make sense of the code. So you will have to be a better programmer than the original programmer to make sense of this sparse code. In other words, if you have to ask how to modify these files you're not qualified to do this.
Good Answers: 44
Re: programming
06/29/2011 1:49 PM
Yeah, you get thousands of unidentifiable lines of machine code unless you have the original working files. Some of it is identifiable, but it cannot be re-compiled without the entire structure intact.
Unlike most things, software needs a manual to assemble the parts, regardless of the sex of the operand.
Good Answers: 88
Re: programming
06/29/2011 7:04 PM
With a HEX editor. Amazing that you know assembly and missed that. S.M.
Register to Reply 4 comments
cuba_pete (1); dcpppf (1); redfred (1); SimpleMind (1)
