Previous in Forum: Material of Construction   Next in Forum: Differece Between Variable And Constant Spring Hangers.
Crossed Helical Gear Design
07/03/2011 9:14 AM
Dear frnds,
Crossed helical gear design- Reg, if you know plz revert back to me..
Existing available data are follows,
1. Gear Helical,
No. of teeth : 14 nos
Addendum modification co-eff,: -0.4
Helix angle: 67 deg 15 mins
PCD,:28.32 mm
2. Helical pinion data:
No. of teeth : 9 nos
Addendum modification co-eff: -0.2
Helix angle: 28 deg 45 mins
PCD: 7.89 mm
Common to both gear & pinion,
Tooth form : shifted gear
Tooth: Full depth tooth
centre distance : 18.3 mm
Module: 0.8 mm
pressure angle: 20 deg.
Shaft angle: 96 deg.
From the above data, I need justification for addendum modification co-eff, helix angle & PCD relation ship.
How to arrive addendum modification co-efficient factor?
Thanks & Regards,
Prakash R
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Pathfinder Tags: gear design
Good Answers: 183
Re: Crossed Helical Gear Design
07/03/2011 2:13 PM
Correction factors which are a shift of theoretical generating profile. They are object of CHOICE, there are indications how to do it and those make me ask why for small nr. of teeth the correction are negative which increases the risk for root undercutting. If it is so then the gears are not designed to transmit power or torque but only for kinematics. The choice was done in order to obtain the wished or imposed distance between centre lines. This is the distance between the 2 planes in which the shafts are.
