Previous in Forum: Galvanic Corrosion   Next in Forum: UPS Transformer ?!? Specifications - Power Supply?
Engine starting batteries, etc.
07/04/2011 6:07 PM
Why ground a battery with voltages of 12 and 24volts?
Thank you for your help - By far the best info site!
Re: Engine starting batteries, etc.
07/04/2011 6:19 PM
To reduce the amount of wiring required to provide a return path. Also by having the radio's return path at the same potential as the sheet metal, the sheet metal consistently works as a reflector for the antenna.
07/04/2011 6:44 PM
Thank you. I felt that it was an econmic reason however I didn't consider any contribution to RFI (if that's what your referring to)
07/04/2011 9:10 PM
Not RFI but antenna gain.
Register to Reply 3 comments
