Previous in Forum: 3 Phase Compressor   Next in Forum: PSTB - Purpose of Phase Segregation?
Power Transformer Low Voltage Protection
07/06/2011 6:25 PM
We have been taking over the Maintenance of Electrical Power Distribution System.
Most of the system have been installed by contractors We are finding many Power Transformers that do not have Low Voltage Fuses installed.
When the Power Company install a system they have a "low Voltage Bar" on the pole with Block fuses installed where the Low Voltage connections are made that go to the distribution panel.
The rule here is after the meter is your responsibility. We have also found out that the power company will no longer stock the low voltage fuses.
Example the low voltage out (220-380) 3 phase of a 250 kva Transformer the secondary is fused with 400 amp block fuses, at least that is the way the power company and we do it.
I just need comments, help, advice not "get an expert" I am all we have that wires to NEC standards. (when we can) Pole grounds are also a problem, they never test them we usually need to install a new ground rod at the MDB and connect it to the line from the pole ground. AND do we bond the neutral to the ground bar in the MDB?
Thanks
Re: Power Transformer Low Voltage Protection
07/06/2011 10:03 PM
Quote "Most of the system have been installed by contractors We are finding many Power Transformers that do not have Low Voltage Fuses installed."
Do the conductors not terminate in a panel? Is the not protection in the panel? How long are the secondary conductors?
Quote "Example the low voltage out (220-380) 3 phase of a 250 kva Transformer the secondary is fused with 400 amp block fuses, at least that is the way the power company and we do it."
The full load on the 250 kva is 380 amps. In my opinion the fusing is too close. You could go to 125% of the FLA. Of course it depends on the conductor size.
If you are useing the NEC
Good Answers: 44
07/07/2011 1:16 PM
I can address the last one...yes. Bonded at the serving transformer (assuming delta/wye, may be assuming too much) and the first disconnect...in this case the MDB (main distribution board?).
07/07/2011 7:15 PM
Let me ask this.
Is protection required for the secondary side of a power transformer.
If a short happens between the transformer secondary wires and the MDB main breaker, what protects the transformer from damage?
Thanks
Good Answers: 59
07/07/2011 11:08 PM
Never mind code, er, mind it, but go beyond it, into the area of common sense. EVERY power circuit needs a protection against short. It is a rare, purpose built circuit, that does not require protection against short. So, normally all do. Even at very low voltages, automobile type, very cheap fuses will protect.
Going down on these logical steps, I fail to grasp, why the original questioner even asks the question. Slavishly sticking to what was done before? I would review all, and do the right thing, erring on the safe side, code or not.
Good Answers: 61
07/08/2011 10:17 AM
Some utilities install secondary fuses on overhead transformer secondaries, but most do not. My utility does not use them. We've never found enough of a benefit to justify that cost. Over the last 20+ years I can't remember a single time we replaced secondary wiring due to overcurrent.
You should note that if the transformer and service drop are owned by the electric utility (power company), the NEC does not apply - see article 90-2 (b)(5). If the equipment is not owned by the utility, fusing at the transformer secondary is still not required if you meet the requirements of article 240.21(C) or 240.21(D).
And as cuba_pete has already stated, the neutral and ground must be bonded at both the transformer secondary and the service entrance equipment (MDB).
07/08/2011 3:32 PM
Quote "Do the conductors not terminate in a panel? Is the not protection in the panel? How long are the secondary conductors?
If you are using the NEC" go to 240.21. I left this off my post. It covers transformer secondary overcurrent protection.
Anonymous Poster (1); cuba_pete (1); leveles (1); pwr2thepeople (1); wareagle (2)
