are you looking for information on sensitivity and speed of film/digital still photography. or establishes guidelines for the exchange of information between cultural heritage institutions.
or the describes the principles and framework for life cycle assessment (LCA) including: definition of the goal and scope of the LCA.
A little more information would be good. Like what your working on that needs the codes.
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
The combination just seems odd/ inappropriate for a forum.
ISO -200 you have described (Film speed, used especially in a bit lower light conditions, and in case of that the higher speed eg 400 etc may be used. Also may be the Life cycle assessment (But that should be ISO14 Series eg 14040, 14044 etc?).
Combine that with ISO 2006 - high-speed mechanical stability of synthetic rubber latex.
Now I wonder why the OP wants the film and the other thing.....
Note: All inppropriate words are removed hence do not press report button
OP- No one is either going to point to a link or give you any copyrighted material here. Read the relevant FAQ and policies of CR4
Please go to the www.iso.org select the standard and press the purchase button.
