Previous in Forum: 1990 Buick Century...Stalling and Turning Back On   Next in Forum: Geometry of Car Suspenson
Testing Starter-Generators
07/08/2011 8:19 PM
i have a alot of delco starter-generators off old garden tractors that i'ld like to test. most have an output of around 30 amps it has a battery terminal and a field terminal that runs to an older style voltage regulaltor. i don't have an engine that i can mount them to. i don't want to pay to have them all tested. any advise would be apprecieated.
Re: testing starter-generators
07/08/2011 9:30 PM
Build a test fixture. It could be as simple as a board with two holes in it that lets you use a big hose clamp to hold the device. Then, with pulley chucked into a drill and a V-belt you can drive the S-G.
The rest you should be able to figure out.
Good Luck.
07/10/2011 12:34 PM
Like Lyn said, build yourself a simple test fixture, and use a 12 volt DC motor, or a 110 AC motor to turn your test equipment. A 12 volt starter is better than nothing if thats all you have. A few simple gauges should tell you everything you need to know.
Life is tough, but it`s tougher if your stupid, John Wayne.
Good Answers: 137
Re: Testing Starter-Generators
07/09/2011 10:33 AM
I would check
1. It doesn't smell of burnt electrics
2. the commutator and brushes look in good condition, and the brush wires are OK
3. the field resistance is reasonable, about 4 ohm (measured between field terminal and S-G body). Much lower indicates a short to earth, much higher a break in the coil.
4. the rotor winding resistance is low, < 0.1 ohm at a guess (measured between output terminal and S-G body). Much higher means a break in the coil.
5. lift the output brush off the commutator and check resistance between output terminal and S-G body. Should be high, low indicates a short to earth somewhere
If it passes all that there's a good chance it's fine.
Codey
07/09/2011 10:36 PM
thanks, this is exactly the information i'm looking for.
Register to Reply 4 comments
Codemaster (1); jlstitt (1); lyn (1); rcrain (1)
