Previous in Forum: Technical Consultation   Next in Forum: Cooling Technology For Future Nuclear Reactors
Small Diamond Grinding Wheel
07/12/2011 11:29 AM
Application: Precise form ground into tungsten carbide. I have a high speed spindle capable of 45,000 RPM. The wheel is flooded with oil based coolant at 90 PSI. The stock mandrel mounted wheels are too course and the corner does not hold up. The plated wheels have too large of a corner. I need help in getting better wheels of 220 or finer grit.
Re: Small diamond grinding wheel
07/12/2011 11:38 AM
07/12/2011 11:50 AM
Yes, I have not found anything on the internet. I forget to mention that the wheel diameter needs to be between .375 to .437.
It is not a mistake if you learn something from it.
07/14/2011 12:09 AM
Contact abrasive wheel manufacturers.
07/17/2011 11:20 PM
Anonymous...,
We offer several types of Diamond form wheels that will get the job done.
call me: 888.586.8783
Bill Herbst
Global Superabrasives
www.globalsuperabrasives.com
billherbst (1); Harvey Patterson (1); pantaz (2)
You might be interested in: Contact Wheels, Wheels, Grinding Wheels
