Previous in Forum: 55 KW Siemens Motor Tripping   Next in Forum: Shared Gas/Hydro Trench (Non Utility)
Transformer Neutral Grounding
07/13/2011 10:09 AM
Some power transformer neutral(Star) are earthed with Neutral Grounding Resistance(NGR) and others are directly grounded.What is the logic behind it and what should be the value of the NGR?
Pathfinder Tags: transformer
Re: Transformer Neutral Grounding
07/13/2011 2:57 PM
See previous threads on CR4 regarding this commonly-asked subject. The search function is on the right hand side of the screen.
Good Answers: 170
07/27/2011 10:01 AM
Generally Low Volatge Winding Neutrals of Transformers are Solidly Earthed and Medium Voltage Winding Neutrals are earthed through an impedance. To understand the logic, please attend to our training programme on Earthing.
The value of NGR is: Phase Voltage of the system to be earthed / desired earth fault current.
Register to Reply 2 comments
