Previous in Forum: Material Standard   Next in Forum: Mechanical Estimation
Tolerances on Plastic Bush
07/13/2011 11:42 PM
I wanted to insert the plastic bush (Nylon) into pipe (OD Dia 19, 1.6mm thk) as tight fit, what should i use the tolerance on the Plastic bush.
Another case is die cast component to Pipe.
Good Answers: 12
Re: Tolerances on Plastic Bush
07/14/2011 2:50 AM
Welcome to CR4; more details, like application, length of brush, etc & if possible pics please!
Subramanyam
07/14/2011 4:04 AM
Did something similar to this previously. Googled "tolerance and fit tables" and found it.
Register to Reply 2 comments
