Previous in Forum: Most Common Engineers on CR4?   Next in Forum: How to Become an IBR Inspector?
Guide Me... Plz..
07/16/2011 12:21 PM
iam working as electrical maintenance engineer... i jst started my carrier.... i want to increase my knowledge... for tis i have to choose erection side or testing&commissioning side.....????? pls guide me.... and i shd helpfull for my future too....
Good Answers: 53
Re: Guide me please.
07/16/2011 12:54 PM
Guidance Number 1
Less knowledge is workable for a maintenance engineer as He can be trained with time, But little bit of carelessness and casual attitude is never acceptable to any engineer.
Hobbies - Automotive Performance - New Member Hobbies - CNC - New Member
07/16/2011 7:04 PM
are you a maintenance engineer?
It is better to fail in originality than to succeed in imitation.
07/30/2011 12:52 PM
thnk you every one for ur valuable suggestion....
iam Mohammed Ali .N completed my electrical engineering in 2009, currently working as maintenance engr... iam trying hard to enter these two sectors.. please if any one knw any recuirtment in testing & commissioning or erection pls help me.... my email id is <email removed> iam from chennai ( INDIA )...
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Re: guide me... plz..
07/16/2011 11:08 PM
You should undergo a period of training under a well experienced and qualified engineer.Learning only by own experience will create trouble in the workplace and will take a lot of time to gain proper knowledge.
pnaban
Re: Guide Me... Plz..
07/17/2011 9:47 AM
Speaking from my own experience, A simple response is Testing and commissioning. You will learn more and be able to further your career.
However, If you truly want to become an expert in your field, experience in both sectors is a must.
When you have experience in both sectors, you will have a better understanding of the complete system. You will be able to locate the source of problems quicker.
As a trouble shooter, knowing how and why a machine in installed a particular way is often helpful.
As an installer, knowing what needs to happen for a good clean start up makes you more proficient and valuable to your company.
In the end you have to decide which area you wish to pursue. Knowing what is required in each area may help you decide.
Good Luck!
repeat problems can not be solved by the same way of thinking ( A. Einstein)
07/17/2011 10:59 AM
For testing and commissioning one should work with either a Consultant or a Utility.
pnaban
07/17/2011 11:35 PM
I myself was a miantenance engineer once. Its good for kick start your career, but end up its too tiring as well as the arguments with other departments when trouble occurs. We are ,most of the time, at the losing side.
So, quick jump start to a career, a hands on maintenance engineer. Then, understanding all the machines, and switch to Testing & Comm. Owh, btw, im doing that now.
Just sharing fromm my own experience, a bumpy one, but a nice ride in all.
Register to Reply 7 comments
dthomas16 (1); Economist (1); marses (1); mohsinhamid (1); pnaban (2); rakesh_semwal (1)
