Previous in Forum: Earthing in Power System   Next in Forum: Power System Protection
Rating of Equipments
07/17/2011 1:16 PM
what is the normally rating of i.d. fan , f.d.fan, nd feed water pump motors?
Re: rating of equipments
07/17/2011 1:56 PM
normal -throughput
klearzen
07/17/2011 2:09 PM
means what? please specify......for normal condition what usually used?
07/17/2011 2:40 PM
nikunjmalaviya,
This may come as a shock to you, but the rating is directly related to the size of the motors connected to the pumps.
You give NO INFORMATION that is useful.
Look on the nameplates of the motors you have. Do you know what they look like?
07/17/2011 3:10 PM
The "normal" method for asking an informative, precise question is to provide enough information so people know what you are asking. This means to not use any undefined acronyms like i.d. or f.d. or nd. While it is unlikely that you are referring to a frequency dependent fan or a neutral density fan or even an incremental displacement fan, I can think of scenarios that these could be valid acronyms.
Good Answers: 804
Re: Rating of Equipments
07/18/2011 1:53 PM
ID and FD are fairly common terms for fans, but I have no idea what ND would mean with regards to feed water pumps.
But other than that, your question is still meaningless. Fans and pumps are "rated" to do the work you expect them to perform. I don't see an issue to question here. It's like asking "How long is a piece of rope?"
07/18/2011 3:38 PM
OK, I'll bite the offered lure. Is ID Inner Diameter and FD Fan Diameter?
Good Answers: 804
07/18/2011 4:54 PM
Induced Draft and Forced Draft fans, basically Suck or Blow... usually in relation to a boiler air supply.
Register to Reply 7 comments
JRaef (2); klearzen (1); lyn (1); nikunjmalaviya (1); redfred (2)
