Previous in Forum: Pressure and Velocity   Next in Forum: Flow Control Valve or Pressure Regulator?
Failure of Graphite Tubes
07/21/2011 12:18 PM
Sir
In our plant we using graphite tube heat exchanger for concentrating the Phosphoric acid. Temperature of acid will be around 90 deg C. nowadays we experience frequent tube failures. we checked most of possibilities, all goin fine..
Help me to overcome this problem.
Re: Failure of Graphite tubes
07/21/2011 12:26 PM
Siva,
This morning I tried to start my automobile by turning the key. Nothing happened.
Help me to overcome the problem,
07/21/2011 12:37 PM
sir check for gas level in the fuel tank..
Good Answers: 53
07/21/2011 12:58 PM
You just told failure, Not that what is the kind of failure, and what all possibilities you had already studied? so that other can rule out those and think some new one.
Re: Failure of Graphite Tubes
07/21/2011 3:10 PM
There are failures and then there are failures.
07/21/2011 3:16 PM
On a less sarcastic level, you need to go back over your failure reports and look for a common thread or factor to your failures. Maybe the replacement tubes are not the same quality as your original tubes. Maybe something other than the tubes have been damaged that you are not replacing. You have the pertinent data somewhere in your system. We do not.
07/22/2011 6:50 AM
What kind of failures are you seeing? Tube breakage, Plugging ???? Are you using tubes from the manufacturer or substituting?
07/22/2011 7:38 AM
Have you tried contacting the R&D division of Graphite India Limited?
http://www.graphiteindia.com/graphitetube.htm
They may have a solution.
bioramani
Register to Reply 7 comments
Anonymous Poster (1); bioramani (1); burt (1); rakesh_semwal (1); redfred (2); sivabalan (1)
