Previous in Forum: Capacitors Capacity   Next in Forum: Small Generator Charger Inverter Set
PF and Harmonic Distortion
07/23/2011 3:26 PM
plzzzzzzzzzzz
i would like to know about the following case
is the power factor affects the harmonic distortion of the system?
what is the relation?
Re: PF and Harmonic Distortion
07/23/2011 4:54 PM
Good Answers: 44
07/25/2011 2:07 PM
GAA!!! Information Overload!!!
Elementary information is so easy to find...
07/25/2011 2:27 PM
It's like Click and Clack, when they play "stump the chump"!
07/24/2011 10:27 AM
Yes, the lower pf , the higher harmonic distortion. The exact relation, you have to do some intensive maths , such as FFT, or by circuit simulation . Also depends on source impedance.
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
07/24/2011 1:39 PM
Lyn has covered it. The proper link for you is the issue. Why are you asking? What is the load that you need to address or fix. One of the biggest problems for power companies now is the nonlinear load issue and most supplies in the US now must use a technology called Power Factor Correction (PFC). The link provides a good explanation / overview of the issue.
Working to end the use of carbon for energy
bravo88 (1); cuba_pete (1); lyn (2); regsoft (1)
