Previous in Forum: Why Use a Transducer for Electrical Sensing?   Next in Forum: ENSURE YOUR LED MODULE'S "LIFE TIME"
What means the "Million" color?(LED module )
07/28/2011 11:31 PM
How should they be mounted in the wheel well?
Before removing the wheel, you should hold the module in a few locations behind the wheel until you find a suitable location. Play around with some different options. We find it works best if they are mounted on or behind suspension components.
The Million color Flexible Led module s have red, blue, and green LEDs. They come with a tiny controller which automatically fades through millions of colors.
Can I use these for underbody glow under the car?
Yes! The result will be amazing. Try the 6 foot strips for a wheel-to-wheel gapless glow Led module.
Which wire is power and which is ground?
The red wire is 12v +, and the black wire is 12v - (ground). If you accidentally connect it reversely, no damage will happen.
----------http://www.ledmodulelight.com
