Previous in Forum: Eating Dates & Honey   Next in Forum: Viscoelastic Material to Simulate Body Tissue
Epoxy Removal
08/04/2011 6:44 AM
Are there any chemical that can disolve or remove epoxy?
Sharing knowledge is one thing that defies basic arithmetic logic --- the more you share, the more you get!
Re: Epoxy Removal
08/04/2011 7:28 AM
Yes. Methylene chloride is one. Do a google search on stripping epoxy. I think there are more environmentally friendly options out there. Sand blasting also works.
Good Answers: 53
Re: Epoxy Removal
08/04/2011 8:04 AM
If possible you can heat it up to 1800C and scrub it.
Re: Epoxy Removal
08/04/2011 1:47 PM
Is this posted in the BioMed section because you need to remove the epoxy from your body?
If yes, the other comments might not be things to try.
Good Answers: 53
Re: Epoxy Removal
08/04/2011 1:55 PM
Good point.
Re: Epoxy Removal
08/04/2011 6:16 PM
Some how my mouse couldn't aim properly, it hit the wrong section.
Re: Epoxy Removal
08/04/2011 3:25 PM
What type of epoxy?
Re: Epoxy Removal
08/04/2011 7:15 PM
example , epoxy used for IC packaging . I am not an expert in epoxy, what kind of epoxy we normally see in products?
Register to Reply 7 comments
bravo88 (2); Doorman (1); jack of all trades (1); kramarat (1); rakesh_semwal (2)
