I am having problems getting HF gas from a gas bottle to an instrument that I need to test. It looks like the gas is being absorbed somewhere! I am using a certified HF bottle with 100ppm Balance N2, Stainless steel "Dial a Flow" pressure regulator but doesn't seem to get a response from the instrument. I know the instrument does respond to HF as I have tested it at a sister company but I don't know what I am doing wrong. Someone has told me that I need to "pickle" the bottle regulator and stem with the gas for few minutes. I did that and there seem to be some response although small but now I am back again with no response. It is the first time I had to handle HF gas and I might be doing something wrong. If you have any experience handling HF gas, I would like to hear from you of any similar problems and how you overcome it. Your prompt comments will be very much appreciated as I need to test and calibrate this instrument before next Tuesday. Many Thanks
