Previous in Forum: Direct Transfer Trip   Next in Forum: Indicating Lights
Synchro Check
08/08/2011 1:36 PM
what are the steps of synchro check for transmission line connected to grid?
Good Answers: 244
Re: Synchro Check
08/09/2011 8:01 PM
The synch-check relay determines the condition of synchronization of the both side of the feeders and take the decision to allow closing the breaker. A synch-check relay first checks the voltage difference, frequency difference and the phase angle between the both side of the feeder. If these values are within the pre-setting values of the relay, the synch-check relay allows closing the breaker, otherwise it prevents the closing.
This thread also may help:
http://cr4.globalspec.com/thread/64672/Synchro-Check-Relay
- MS
