ZONEDING Machine is a professional rotary dryer manufacturer,our factory with sincerity, practice,quality, service, innovation, development, with the aim of being responsible for every procedure,every product, every user, gets many positive criticism from customers.
Coal slime dryer mainly consists of draft fan, scattered, belt device feeder, feeding machine, rotary roller, heat source, belt discharging machine, unloaded feeder and distribution ark to form.The work area of coal slime dryer consists of gaide material area,lift up the stripper plate area,the material discharging area and clean up area.
1.The guide material area: after wet coal slime goes into the guide material area and high temperature hot air contact area soon a lot of coal slime water is evaporated.In big lead angle to copy plate, coal slime can't form copy dynamic binding and was introduced into the next working area;
2. Cleaning area: Wet coal slime in cleaning area is copy plate start to copy form curtain material condition.Material falls easily formed wall binding phenomenon.In the cleaning up area, for mechanical design having cleaning device, cleaning device reasonably cleans material adhesion on the wall. In the process, cleaning device also plays materials group ball agglomerate crushing effect, which increases the heat transfer area, improves drying rate;
3. Tilt stripper plate area: wet coal is already low moisture loose state and don't have the binding phenomenon in this area.After heat transfer,coal slime reach the demand water moisture,then goes to the next material area.
4. The material area:In this area,do not set up roller copy plate, the material rolling taxi to discharging mouth, finish the coal slime dryer drying process.
ZONEDING Machine professionaly design rotary dryer,sand dryer,coal slime dryer, which have the advantage of high capacity, perfact drying effect, low energy consumption, low cost. The rotary dryers by ZONEDING are your first selection,welcome to consult and choose the most suitable one to buy!
