Previous in Forum: The Pixel Concept Car   Next in Forum: How to Seal a Cracked Radiator?
11 comments
Troubleshooting Ford Explorer
08/11/2011 6:49 AM
Problem: Ford explorer 2004 eddie bauer
Dome lights, power windows, radio, fuel gauge all stopped working at the same time.
Whats wrong?
Re: trouble shooting
08/11/2011 7:31 AM
Check your fuses.
Re: Troubleshooting Ford Explorer
08/11/2011 11:14 AM
Dead battery.
Oh, other stuff works? What other stuff?
Good Answers: 101
08/11/2011 11:28 AM
Those may be using a shared Fuse. Which I would suspect has blown... as was stated before.
08/11/2011 5:12 PM
Do you have a wiring schematic?
Good Answers: 52
08/11/2011 10:39 PM
Here's the manual:
http://www.scribd.com/doc/23885112/2004-Ford-Explorer
Check page 186 and following pages.
Mark Bingham
Relativity PL
Good Answers: 42
08/12/2011 2:29 AM
Its a FORD.
Found On Road Dead.
Fix Or Repair Daily.
(Yes, I own a F350) Super Duty.)
Good Answers: 44
08/12/2011 10:59 AM
F**ked Over Rebuilt Dodge
08/12/2011 5:56 PM
Please allow my prejudice! I'm a longtime Ford guy, but I tried some Dogs, Dodges, for service trucks - and they were - lots of service on them. The crew invited me NOT to buy anymore. Still just my prejudice. -- JHF
08/12/2011 5:06 PM
I've notice on newer Fords, these items stay on after the key switch is turned off untill a door is opened or they time out. This leads me to believe there is a relay involved somewhere. -- JHF
Good Answers: 101
08/12/2011 5:30 PM
Good thinking... Yes, if the fuse is good, next check would be the relay... If the Relay is good, maybe there is an issue with one of the door switches or wiring/bad ground etc.
08/12/2011 6:59 PM
My 2004 Edie Bower had window operation problems on hot days, getting worse over time. Driving the car would cool things down, after which I could open the windows.
Finally failed totally. Seems interior lights were finally noticed to be involved as well .
Found failed Accessory Delay Relay FOAZ- 14N089-A. Less than $20 in 2006. Seem to recall it as a small PCB.
This occured around 150,000 miles. Explorer now at 220,000 miles. The only larger failure was the fuel pump at the same time.
Register to Reply 11 comments
Circuit Breaker (2); cuba_pete (1); Doorman (1); GW (1); kramarat (1); lyn (1); Not too Smart (1); Relativity PL (1); RVZ717 (2)
